Rotary Cutter Land Pride RCR2512
   / Land Pride RCR2512 #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
Show and tell 12' rotary cutter for 50 to 75 PTO HP tractors. This one will be in the classifieds soon I hope.
   / Land Pride RCR2512 #2
HMMMMMMM--95% of cut material is in left wing. Don't think I'd like that.
Well truth be told left side was in much tall and thicker, In the same type and thickness it does a nice job.
   / Land Pride RCR2512 #4
DDT, have you been able to run this unit? Not sure I totally agree with left side in heavier materail. In front of right wing looks just as heavy as left wing. I haven't seen this run but I would think there should be something behind the right wing and more behind center. I have seen a batwing run and as I recall the distribution was better. Oh, well, some may not be as particular as I am.
   / Land Pride RCR2512 #5
You can buy baffle kits for most bat wing mowers. Tends to stop a lot of the windrowing when mowing. I have one on my JD HX15.
Most batwings will have 2 of the 3 sets of blades that rotate toward each other, creating the windrowing effect. The baffle kits are steel rings under each deck that keep the material contained to each wing.
   / Land Pride RCR2512 #6
If you really look at the pic, it's very obvious that the material on the left is heavier than that to the right. Very obvious.
Nothing at all wrong with the cutter. It's doing exactly what it should do and I'd be very happy with a rig cutting like that. It's not a lawn mower after all.
Looks like a nice shredder. I'm more of a single-wing 12' cutter fan but nothing wrong with it at all.
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 GIYI GY-PG72C...
Unused 2025 CFG H15 Mini Excavator (A50322)
Unused 2025 CFG...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52748)
NEW 2022 Load...
