LandHope 220
   / LandHope 220 #1
jeffmiles
Kubota L3000DT- MIA
I have a LandHope 220 with a popping noise in the rear end. No tire movement while in gear. If I place in 4WD front tire pull. Rear just pops. It started happening a while back but only in a heavy strain. I am ordering the closest Massey tractor service manuals I can find. Where to start. Could it be a axle bearing completely worn out? It's been such a good tractor. Even if I can't read the operating instructions, or controls, or the shift patterns, or the tach or anything else on it, I still like it.
Thanks in advance for your direction.
Jeffrey
   / LandHope 220 #2
Does it move with the differential lock on? If so, you probably have a broken brake pinion shaft. If not, probably a bad ring/pinion.
   / LandHope 220
Len, If either is the case, can you acquire parts for the fix?
   / LandHope 220 #4
I can get them if they are available.
   / LandHope 220
I am returning back home this Thursday 4/10. I'll tear down and inspect then. I'll send you a list if I cannot find locally. Wish me luck.
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
Pallet of (11) 10 Lug Misc Wheels (A51573)
Pallet of (11) 10...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
1988 Ford F-250 Pickup Truck, VIN # 1FTEF26N1JNA71750 (A51572)
1988 Ford F-250...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
