Landpride FDR1660 Finish Mower Question
   / Landpride FDR1660 Finish Mower Question #1
Pa Pa Jack
Hodges, SC
Mahindra 3016
MY finish mower has always been rock solid. Today I was running over the lawn to get rid of a million daffodils that have shown up this year. Suddenly I can't keep the belt on the pulleys. I checked the tension and adjusted it but the tensioning pulley flops around badly when I try to run it. The pulley is solid but the entire assembly has a lot of slack in it at the mounting point. I can raise and lower the whole assembly at least a half inch. I looked at the blades thinking maybe one is badly worn but they don't look too bad although I haven't sharpened them in two years. All the other pulleys are solid and spin very freely without the belt. No signs of bad bearings.
Any ideas?
   / Landpride FDR1660 Finish Mower Question #2
Check for a flat spot on the belt.
Thanks Leejohn, that may be the issue. I found two flat spots on the belt. I can see how that would set up a vibration throughout the whole system.
Can anyone recommend a source for a "Good" 106 inch belt? The prices vary so muck and they all claim to be Kevlar belts.
2024 JOHN DEERE FC20M LOT NUMBER 74 (A53084)
2024 JOHN DEERE...
JOHN DEERE 54D LOT NUMBER 160 (A53084)
JOHN DEERE 54D LOT...
8ft Perforated Metal (A51573)
8ft Perforated...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
