Landpride grooming mower gauge tires??
   / Landpride grooming mower gauge tires?? #1
countrybumpkin
Elite Member
Kioti, kubota
I bought a used AT2572 landpride grooming mower and need two new tires for the front gauge wheels, the ones that I took off are load range B 500 pounds at 50 psi, I have two brand new tires in the shop I have no other use for , that are not load range B, they are 300 lbs at 30 psi. Would these work to replace the two old tires or are they to soft. Hate to buy a couple if I have some that would work right here.
   / Landpride grooming mower gauge tires?? #2
That mower is a 72" unit and probably weighs about 700-800 lbs (more or less). At worst case, that's only 200 lbs per tire. I'd try the new tires and put the maximum air pressure in them.
BTW, if you didn't get a manual for your mower, try the Land Pride web site. They've got a lot of manuals for downloading
ok thanks.
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
2121 (A51244)
2121 (A51244)
