Landtrack 360dtc
   / Landtrack 360dtc #1
Adam2012
Landtrac 360dts 2000
I was running my landtrack today and stalled the engine, when I went to restart it nothing happened no dash lights, fuel pump didn't kick on glow plugs didn't even kick. I checked my battery and my grounds even have power at the starter, and the switch when it is off any ideas????
   / Landtrack 360dtc #2
I would start with checking all the wires and connections. Hard to say what is wrong but from what you described seems like bad/fualty electric flow.
It'll probably be the whatjamajig way down under the thingamabob located behind the hardest place to work.:D
   / Landtrack 360dtc
I thought it might be some kind of safety switch or something. I know it won't start if the pto switch is on, I didn't know if there was something else that I might be overlooking ????
   / Landtrack 360dtc #4
Various sensors will shut it down.
Seat sensor
Clutch sensor (if it has one)
HST peddle not centered (If hst)
mid-pto swtich
rear pto switch
   / Landtrack 360dtc
As far as I know it only has a sensor on the pto. Another thing is when I was checking everything I crossed the solenoid and it didn't do anything. That is the reason I think it is something other then a short.
   / Landtrack 360dtc
Thanks guys it must have been a ground after all, took the ground cable off the frame and cleaned it good and it started up
KBH Tender Trailer (A56438)
KBH Tender Trailer...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
