Lawn cutting
   / Lawn cutting #1
Ebee
crest hill ill
john deere 111
Hello everyone: Have a question rergarding an older riding mower as best as i can tell from buying parts I have an older 111 model I replaced the drive belt on it and after putting the deck back on and operating the tractor everything worked except when I activate the blades by pulling the control lever the Engine dies.any ideas?
   / Lawn cutting #2
Frozen spindle bearing, or tensioner pulley bearing? can you rotate the blades and belt assembly by hand?
   / Lawn cutting #3
If the problem is not the above, it could be in the government-approved safety wiring system. If the tractor "thinks" its in reverse, or "thinks" there's no one on the seat, it might shut the engine down.
Sorry for the late response, but looks like no one else threw this thought in.
Good luck!
   / Lawn cutting #4
Spindle brakes not adjusted properly?
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
