LB1914 for 3pt work?
   / LB1914 for 3pt work? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My current tractor is a 45HP Kubota, which I use primarily for TLB work. I have recently acquired a long gravel driveway, however, and need a road-maintenance machine. Unfortunately, it is a PITA process to remove the backhoe and set up the 3pt hitch from my big tractor, so I'm thinking of getting a smaller machine to primarily run 3pt implements, like york rake and grading blade. I came across a 400-hour LB1914 with loader for what seems like a good price. How wide is the rear end on these things? Is a 6' blade big enough when it's angled? I'd like to hear some opinions of the machine, pros and cons, and I'd like opinions on what fair value is for one.
Thanks much - JayC
   / LB1914 for 3pt work? #2
That tractor with loader should retail for around $6000-7000. You can change the width of the rear tire setup. It should normally handle a 6 ft blade angled ok, as well as the other implements you mentioned. Ken Sweet
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRACTOR (A51243)
2012 MACK PINNACLE...
Ford Super Duty Pickup Truck Bed (A49461)
Ford Super Duty...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A51039)
2022 JCB 3TS-8T...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
