DJP
I have a Mahindra 4500 2wheel drive, it run a older handy-600 BIG RED bush hog. First thing, one of my blades broke in half under my bush hog. It has two blades. I need to replace both blades. Can someone tell me tell me if this HANDY BIG RED 600 is a BUSH HOG or a ROTTERY CUTTER? I think it the 6-foot model. What side blades it uses? How long the blade need to be? Where can I buy a replacement blade?
Another issue is at the back of my Mahindra where the turning pin(whatever it is called) that turn the bush hog, is leaking fluid. This is the pin where the bush hog turning shaft slides on, that turn the bush hog. I have a seal leak appear to be coming around this pin. As I turn the bush hog shaft, there is a small string leak coming from the bottom side.
If so how to you repair/replace the seal around that pin. Can I replace the seal myself. I am not a tractor MECH. but since I had this tractor I have replace the fuel tank, which involve taking off the sterling wheel, and have replaced both. I have taken off the stump jumper( a **** of a job)and replaced. I have taken off the front wheel sterling cylinder and replaced. This bush hog pin that turn the bush hog has five to six bolts on a plate, that appear to hole the seal in place. Can you pull out the seal after taken loose these bolts, or is the seal dipper inside? Can I pull/knock out the seal?
