Leak in the middle
   / Leak in the middle #1
GMtb42
Spiro, Oklahoma
SOLD Kioti CK20 HST Purchased CK3510SE HST
I noticed the other day a drop of oil on the ground under the tractor, got to looking and saw a couple of more beads of oil coming from a inspection hole in the mid section (section between the motor and rear-end) of the tractor, anyone have a manual and can tell me what it might be leaking in there, can't get a good line of sight to inspect the area. Would be much obliged for the info. 2004 CK20HST
Thanks in advance.
Looks and smells like Hydro fluid not motor oil.
   / Leak in the middle #4
Check the test ports on the top and the side of the HST. I believe there are 5 or 6 ports for testing pressures. The ports have a Allen head on them and if they back out the o ring will blow out causing a leak that looks like the main seal on the hst. Hope this helps as it is an easy fix.
Will try and find tomorrow.
I think I found what you are describing, there are 5 plugs, 3 on top in a row and one on either side, they are tight, so main seal? If so what does that entail?
   / Leak in the middle #7
I had this problem on my CK30 and I've read a bunch of people with similar issues. Do a search, I know I've read a couple other threads either in the Kioti forum or the Bobcat forum, maybe somebody answered it. I'm not sure what the cause was on mine, I traded my tractor before my dealer fixed it, but it started with less than 100 hrs.
Got to looking further and saw 2 more plugs under the tractor, those were tight too. Darn!
Okay thanks.
I found this thread after a long search : http://www.tractorbynet.com/forums/kioti-owning-operating/244056-small-hydro-leak-issue.html is this the one you are referring to?
Says o-ring leaking -- tractor split to replace.
toro turf sweeper (A50324)
toro turf sweeper...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
377789 (A51573)
377789 (A51573)
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
