Oil & Fuel Leak-off line size
   / Leak-off line size #1
JLWjr
Ford 1700
What is correct inside diameter of the leak-off line between the injectors on a Ford 1700? Will I have to bleed-off the fuel system after changing this line? Will appreciate any assistance. Thanks.
   / Leak-off line size #2
I used 5/16" rubber hose rated for oil, fuel from local Auto parts store. A 2 feet section of it in a box was less than $3. I reused two of the existing clamps and and add a new clamp on the tank. The hose seemed a bit thicker than the original but the ID was the same. Take a chunk of the old one and compare and contrast to what they have in auto store. A little bigger can't harm as long as Id is the same and you have a clamp on it. No, you don't. Bleed off line is atmospherically vented thru your fuel tank.
JC,
By the way, also got some1/4" Polyethylene line to fit my fuel sight glass/hose. The original was so dark and could not see the fuel at all. As you know 1700 does not have a fuel Gauge ... good part of it that it's got nothing to break either.
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
Kubota RTV500 (A47384)
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
John Deere 12' Grain Drill (A50515)
John Deere 12'...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
