Leaking fuel injector assembly
   / Leaking fuel injector assembly #1
Ben755
Bronze Member
Tx
Yanmar FX28D
I was in the process of changing out the glow plugs on an FX28D, and I noticed that diesel fuel was accumulating on the block near the first fuel injector. I traced the leak to the base of a threaded coupling that the injector screws into. Of course, fixing the problem will require opening the lines and removing the injector. My concern in trying to start the tractor after the fix - anybody have any experience with this ?
   / Leaking fuel injector assembly #2
I would think just bleeding that one injector should do it.
   / Leaking fuel injector assembly #3
I wouldn't worry about getting the injector in 9f you got it out. Bleeding air shouldn't be hard as said at worse you need to crack the line till fuel is present the tighten it.
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2 ROLLS OF CORNING OPTICAL CABLE (A50854)
2 ROLLS OF CORNING...
1979 LUFKIN TRAILER (A50854)
1979 LUFKIN...
100 GAL L SHAPED FUEL TANK (A50854)
100 GAL L SHAPED...
2004 KENWORTH BUCKET TRUCK (A50854)
2004 KENWORTH...
