Leaking hoses on JD 440 loader
   / Leaking hoses on JD 440 loader #1
barngal
West Coast
John Deere 870, Craftsman 24HP garden tractor
I have leaks from 2 hydraulic hoses on my JD 440 loader. I/m hoping its just the hoses, but worried it could be something else.
The leaks are squirting and seeping thru the hoses. The hose on the left (head-end bucket cylinder) squirts out; the hose on the right (rod-end lift cylinder) leaks, but not as much pressure. There are no leaks from hose fittings, or anywhere else that I can see. The bucket functions normally.
The tractor is not not stored under a cover, so I guess it could be sun damage, but I'm concerned that something else may be going on, since 2 hoses have these symptoms, not just one.
Should I just replace the hoses? (I'll replace them all) or ? I replaced all the rest of the loader hoses just a few years ago; these 4 are the only ones I haven't done yet.
   / Leaking hoses on JD 440 loader #2
Replace the ones that are currently leaking. You had a reason to replace the others; were they leaking then?
Yes, a hose on the front of the loader sprung a leak, so I replaced everything except the 4 main ones. The main ones looked newer, the ones on the front were all original. Just figured they were old and sunbaked so do 'em all.
I'm replacing these 4 that are the supply/return lines, since 2 are leaking and a 3rd one has some big cracks at the bottom, figure they are due. My only concern was if there was something else that was causing the 2 top hoses to leak; didn't want to pay for new ones and then have them ruined too. But I'm on my way to Napa to get them. Sorry I couldn't post the pics yet, will do it later if its will help.
   / Leaking hoses on JD 440 loader #4
How old is the tractor? How many hours on it? Does it sit out in the scorching sun/rain/ozone? You could coat the hoses with sunscreen!:laughing:
Yes to pics.
2019 Caterpillar DP35N Forklift (A51691)
2019 Caterpillar...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
David Bradley Manure Spreader (A50515)
David Bradley...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
MAHINDRA EMAX 225 TRACTOR (A51243)
MAHINDRA EMAX 225...
