Leaking water pump
   / Leaking water pump #1
buppy69
Platinum Member
Western NC
Hinomoto E2804, Hinomoto N239,
Can you plug up the weep hole in a water pump and still use it if it is OK otherwise? A local dealer wants $288 for one.
Eugene
   / Leaking water pump #2
No. That is your warning that the pump is going bad. The next warning will be an overheated engine if you're lucky....or a broken shaft and a fan through the radiator if you're not lucky.
   / Leaking water pump #3
Eugene,
Send it to me and I will rebuild it like new for less than half the new pump price.
Thanks,
Bruce
   / Leaking water pump #4
$288 is TOO HIGH. Bruce is right, send it to him. I have never had him do a pump for me but I have sent a pump off for rebuild and it cost me $75. Rebuild is the way to go.
Thanks Fellas.
Eugene
Tri-Axle Police Travel Trailer (A51694)
Tri-Axle Police...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
John Deere 6210E 120HP 4WD Agricultural Tractor (A50322)
John Deere 6210E...
