Leaky backhoe connectors
   / Leaky backhoe connectors #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My Woods 9000 backhoe is leaking when it is parked. The first time I took it off, I had to put a bucket under the hoses - had at least a couple of cups of fluid leak out. I determined that I put it away under pressure, so the next time I was sure to exercise all of the levers with the tractor off before unplugging it. That seemed to work - it sat for 2 weeks w/o leaking. Then, when I happened to be there, all of the sudden there was a puddle and one of the hoses was dribbling somewhat profusely. I don't know if I bumped it (didn't think so) or if it was just an incredible coincidence, but I pushed the leaky connector's ball in and let it pop back out. That appeared to stop the leaking fluid, but it was weird none-the-less. Is this at all normal, or are my connectors shot? There is no leaking when the backhoe is mounted and/or operating.
JayC
   / Leaky backhoe connectors #2
I would spend some good money on high quality coupler connectors.
and be sure to buy caps and plugs.
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2014 JOHN DEERE GENERATOR SET (A51222)
2014 JOHN DEERE...
