Oil & Fuel LEARNED MY LESSON TODAY
   / LEARNED MY LESSON TODAY #1
farmall 55a case
case ih farmall 55a
I was bush hogin the lane today. I had a quarter tank of fuel left and I was mowing the bank and it lost its prime and died! Its still sitting there had to go to work! Hope I can get it going when I get home in the morning! The pump is on the uphill side probably be a pain to get started tho! So the lesson I learned today is that a half of tank of fuel is as low as im ever Gona let it get!
   / LEARNED MY LESSON TODAY #2
Your tractor may have a stopcock on the injectors.This makes it easy to re-prime.
? How do I know if it dose? Just figured id crack the lines by the injectors.
   / LEARNED MY LESSON TODAY #4
thats what i would do crack the line on an injector but it might have a petcock i know even my old chevy 6.2l diesel did near the fuel filter to bleed air off thats was an 85
   / LEARNED MY LESSON TODAY #5
nice tractor you have there
   / LEARNED MY LESSON TODAY #6
been there...done that-
Thought I had enough left to finish mowing but didn't even consider that I would also be going up hill. I was able to put it in Neutral and roll back down the hill with brakes til it was level again. guess i was really out because I had to fill it before it would start (didn't have to prime it)
   / LEARNED MY LESSON TODAY #7
Your misfortune has made me rethink running my Kioti so far down in fuel level, like I did Saturday, it was near Status E, and everything is on a hill here in Branson, Lucky I made it back to the fuel. I will not run it so far down now, after hearing from you. Sorry to hear about your troubles, but thank you for educating me. Good luck in getting yours re-started.
James K0UA
Well i just got it going again! I was rather surprised how easily it I started concerting how it was siitting. Cracked the lines aan blead the system and it started in a min. It took a wile for it to build high rpm :)
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2009 FREIGHTLINER CASCADIA SLEEPER (A51222)
2009 FREIGHTLINER...
