Loader Left Loader Arm Jumpy
   / Left Loader Arm Jumpy #1
Stormtruck2
Bronze Member
Mechanicsville, Iowa
02 JD 4600 FEL, 72 MM Mower, Cab
I have a 4600 with a 460 loader. The right rear arm sits tight and doesn't move a bit while in operation. The left arm on the other hand does a jitter bug while in use.:confused: The arm that I'm speaking of is the arms at the rear of the loader that sits on the mounts on the frame. The mount beam is tight to the frame, the contact pads all look like they are making contact on the mount. It certainly doesn't seem as solid as it was last year. Any ideas greater minds than mine??
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
