Lehr Propane Trimmer w/ detachable shaft -- what attachments fit?
   / Lehr Propane Trimmer w/ detachable shaft -- what attachments fit? #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
According to the Ace Hardware site, MTD attachments (which also means Troybilt) fit. What about Poulan? Amazon as a Poulan PP5000P Pro Pole Pruner String Trimmer Attachment,
Amazon.com: Poulan PP5000P Pro Pole Pruner String Trimmer Attachment: Home Improvement
For $69. Will this fit?
The trimmer I have is this one:
Amazon.com: LEHR ST025DS 25cc Propane Powered 4-Stroke Detachable Straight-Shaft Eco Trimmer: Patio, Lawn & Garden
I just got it, and haven't used it yet. I did pour the oil in it and start it up. No odor! Amazing, after having used a 2-cycle gas-powered one. My "old" one, an Echo GT-200R is actually only a year old and works fine, but is a curved-shaft model, and can't get in under some of the stuff I need to trim under. I'll likely be taking a big loss on this one when I sell it. It is a quality piece, but I was attracted to the 4-cycle propane powered Lehr, as I'm kinda sick if stinking of 2-cycle exhaust after trimming. I'm able to cut the grass with my Kubota G1800 (diesel), and a little push mowing with a standard 4-cycle mower, and not feel the need to shower immediately (unless it is hot and humid) -- but as little as 10-15 minutes with the 2-cycle trimmer, and I couldn't stand to be around myself. It is worse with a trimmer than my chainsaw, I think because the engine is much closer to you with a trimmer. Anyway, I started the Lehr inside the garage with the doors closed and ran it for a few minutes. No odor! This, is of coarse, why forklifts use propane instead of gasoline.
One issue that I had before buying it was that of the environmental impact of disposing of the disposable 16.1 oz cylinders (yes, recyclable, but that still has impact) until I found out that they can be safely refilled from a 20lb propane tank.
2009 International 7600 Truck, VIN # 1HTWYAHT49J188295 (A44391)
2009 International...
Komatsu WA270 (A44501)
2014 CAT 303.5E2 Excavator (A42203)
2014 CAT 303.5E2...
Sears Walk Behind Tiller (A44502)
Sears Walk Behind...
Beverage Trailer (A44391)
Beverage Trailer...
2014 MACK CXU613 (A45046)
2014 MACK CXU613...
