Leinbach B245 U Have one?
   / Leinbach B245 U Have one? #1
Artisan
Veteran Member
Monrovia, California
Kubota BX25
I am not sure if I am looking at the 16-20 or 16-18 #B245 Leinbach unit
yet, no matter it is a little big for a BX25. It may not be too big if I cut
8 discs off it, 2 off each end. Do you own one, does it look feasable? The price is right
so that is not an issue. The issue is can it be done easy or not? I
do not have it here in front of me to figure it out, and I am unfamiliar
w/ them as a whole.
EDIT: It is the LB-B245-20-18 per the owner.
TIA!
This is the unit;
   / Leinbach B245 U Have one? #2
If it was priced real low or an out and out great deal I'd buy it even for worst case senerio "trade bait".
I'd see if I could take off i disk on each end and try it. Remember it doe'snt weigh that much cause its a L frame and not 3 or 4"
tubing. Also on the Leinbach Line w/site they should have specs on it ,just like they probably do on Ted's Everything attachment.com Just my :2cents:
Boone
   / Leinbach B245 U Have one? #3
I do not believe your BX will lift the 6' 9" unit. I have an Older Ford 5' 4" with 22" blades that makes the front very light with out the FEL on.
KC 28in.x90in. Metal V Bottom Feed Bunk (A49339)
KC 28in.x90in...
2125 (A49339)
2125 (A49339)
Komatsu D51PXi Crawler Tractor Dozer (A44571)
Komatsu D51PXi...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A45678)
2016 FREIGHTLINER...
2008 Thomas Freightliner 71 Capacity School Bus #29 (A46502)
2008 Thomas...
1573 (A46502)
1573 (A46502)
