Front-End Loader Level indicator help
   / Level indicator help #1
BayouMan
Gonzales, LA>
JD-2640
Hey guys,
I have a Bush Hog Brand loader on my old JD-2640. The loader was bought used and I had it mounted on my tractor last year.
What I am looking for help on is, I need a level indicator for my bucket. I have looked at other tractors and they either have a rod going through a small pipe with a color change at the point where the bucket is level with the ground, or a ring of sorts with a crook in the rod coming from the bucket, that indicates when the bucklet is level the lowered position. I can get reasonably close to getting the bucket level, but more often than not, I either end up digging down or skidding over when I am trying to get a load into the bucket.
I figure I could fabricate one, but if one is available, already made, I might save myself some time on trial and error process of making one work and also not get heat stroke while trying to make one.
I have done a little searching on google to see if that part is available, but not much information.
Any ideas or pictures of one would be most helpful.
Thanks,
Mike
   / Level indicator help #2
Hey guys,
Thanks,
Mike
The one on Kubota loaders is about is basic as it gets. It's a metal bracket about 4" long on top of the bucket that is level with the bottom of the bucket. After you use a level indicator a while you won't need it anymore. You will be able to tell by looking at the bucket if it is level or not.
   / Level indicator help #3
I think that there available from any dealer.They do help when you,re trying to hurry,saves time trying to look at the bucket:thumbsup:Dave
   / Level indicator help #4
I got mine free from the dealer. My FEL came without the level indicator. When I asked the dealer about it, he provided me one. Said they'd forgotten to put it on. It makes a BIG difference, particularly this winter when I used that thing A LOT, and its important to get the bucket level to the driveway when pushing snow.
Ralph
Well, I have decided to go ahead and fabricate my own indicator. Shouldn't be too hard to do. Bought a piece of 5/16 steel rod today. Should have everything else in my scap pile. I'll post pictures of the build, when I get started.
Thanks for the replies.
Mike
   / Level indicator help #6
I would like to see what you come up with, I am thinking of making something for my kubota I had the little flat plate on the top of my bucket, really didn't care for it. I removed it when I modified my bucked to a SSQA. looking at maybe a rod style with the notch in it.
I am basically copying the set-up that my neighbor has on his JD CUT. Has the rod going from one of the bucket arms, up through a piece of pipe that will pivot. Besides a paint color change at the point the bucket is level, I hope to be able to cut a shallow notch around the rod and make that notch a contrasting color.
I'll probably get started on it tomorrow.
Mike
Well guys,
I got the indicator fabbed, painted and installed today. I think it came out pretty nice, even if I do say so myself.
As soon as I can get help to figure out why my computer does not recognize my camera, I will post pictures. Had my computer worked on a few weeks ago and I have not been able to get it to recognize my camera since. Never had a problem before.
Mike
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2015 GMC Arcadia (A50324)
2015 GMC Arcadia...
2019 CATERPILLAR 299D2 SKID STEER (A51242)
2019 CATERPILLAR...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
