Chipper Liberty Chipper clogging
   / Liberty Chipper clogging #1
Justus14
Independence, VA
Kubota B3200
I bought an 8 Pro series PTO Chipper from Liberty implements High Quality Chippers & Implements, they also make backhoes, tillers and mowers. From the day I received it I致e had problems with the unit clogging up. I have to shut down and clear it twice for every hour of operation. The blades are sharp, belts aligned and in good shape, running at 540 RPM on my B3200 Kubota. Chipping mostly 1 3 green hardwood, occasionally larger pine; do not see any pattern to what I feed it and when it clogs. Liberty thought it was a bad fitting discharge chute so they sent me a new one, fits as badly as the last one so I duct taped up the gap and it still clogs. Now Liberty is totally unresponsive. I think the unit has a design flaw or it痴 just cheap Chinese junk. Has anyone had a similar problem or found any solutions?
   / Liberty Chipper clogging #2
Before it clogs are the chips cutting cleanly or are they long and stringy?
   / Liberty Chipper clogging #3
My 4" wallenstein chipper clogs with small(1" or smaller) hardwood branches as well as soft wood branches. I find it I alternate small with large wood(2-4") the larger wood/chips helps keep the shut clear.
This happens when the blades are sharp as well as dull. I find when the shut is positioned to help create a nice curve/arc for material to travel it is less of a problem... of course alternating wood size and shut direction is not often possible. Hope this helps.
   / Liberty Chipper clogging #4
If it's clogging on smaller stuff (an inch diameter), try feeding a bunch in at a time...say, 6-8 pcs (more, if possible). I have read that works better with dedicated chippers.
Mine is a chipper shredder...smaller stuff (at inch or less) goes in the shredder chute.
RPW, thanks for the interest. Chips are clean. I've seen the long stringy ones produced by dull or damaged blades. The machine runs well just clogs. Very frustrating.
   / Liberty Chipper clogging #6
I have heard that a silicone (? sp ) spray will help. Just something I heard somewhere.
Gordon,
Thanks. I'll give it a try. WD-40 seems to fix about everything else.
Regards
   / Liberty Chipper clogging #8
My 4" wallenstein would choke on green pine needles. Too much pitch. I found running an old dry pine limb thru every 5 minuets or so would help a lot. Cheaper than WD-40 and probably just as effective - turpentine in a spray bottle. The idea is to clean out the pitch and lube the chute somewhat.
   / Liberty Chipper clogging #9
Although my stand alone chipper/shredder is different than your Liberty chipper, I've found that it takes some time to learn the variations of material being fed, how dry/wet/green it is, how fast to feed, etc. Justus14, maybe a little more experience will help with the clogging problem. For example, I've found that there is no way my machine will do anything with yucca. It just balls up in the shredder. Good luck with your solution.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
John Deere 350 PTO Manure Spreader (A52128)
John Deere 350 PTO...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
