lift arm adjuster
   / lift arm adjuster #1
LarryP
I have a S630D tractor and I need to be able to move my lift arms higher so that I can use a posthole digger. I'm looking for either (2) adjustable lift arm levelers, or turn buckles and threaded rod so that I can have some fabricated.
   / lift arm adjuster #2
I can supply an adjustable lift arm levelers, but you should be able to mount a post hole digger on your tractor with the original equipment arms . The top arm of the phd should have several holes to mount the u bracket to. Also your lift arms may have multiple holes. The farther out the lift links are the higher the 3 point will go.
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Bobcat T590 (A53317)
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2017 HAMM H5i P PADFOOT ROLLER (A60429)
2017 HAMM H5i P...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
