Lift arm pins for Land Pride tiller
   / Lift arm pins for Land Pride tiller #1
bossgobbler
Southeast Ohio
Kubota
Good morning! I recently purchased a Land Pride RTR2072 tiller. I need category 1 3pt lift arm pins. If you are familiar with the Land Pride tillers they have two open holes on each side of the tiller where I would slide the lift arm pins through and then use smaller pins to attach the lift arm pins. My question is, should I use semi-permanent pins that bolt on or is it ok to use a pin that slides through each time I hook up the tiller? I bought the slide through pins yesterday that are supposed to be Land Pride pins but they seem long to me. Is it ok to have them a little long as long as the pin diameter is snug? Any help and advice is appreciated. Thanks!
   / Lift arm pins for Land Pride tiller #2
Longer probably won't hurt a thing though my personal preference would be that they not be much longer than absolutely needed.
Won't the standard bolt on pins that TSC sell work?
Payment Terms (MUST READ) (A50775)
Payment Terms...
Electric Concrete Mixer (A51573)
Electric Concrete...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
