Lift arm spacing 1026R
   / Lift arm spacing 1026R #1
fuelhog2000
Dummer, N.H.
2012 John Deere 1026R
I am anxiously awaiting delivery of my new 1026R and would like to know if any 1026 owners could tell me the lift arm spacing? Not sure if it will be 26" for a limited category 1 hitch. Thanks
   / Lift arm spacing 1026R #2
It should be 26" (keep in mind the arms swing a little in and out). The "limited" part of the cat 1 on the SCUTs is the height of lift. Because of the small tires the range of lift above the ground is limited and some attachments, like subsoilers and post hole diggers may not work so well. The geometry of the hitch itself is the same as a full Cat 1.
Thanks, I got a subsoiler for a limited cat 1 but wasn't sure if other non-height dependent cat 1 impliments would work. Appears as though they will as long as I can pick them up.
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A54607)
2017 INTERNATIONAL...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
