Lift pin covers
   / Lift pin covers #1
SammyNole
Florida Panhandle
Kioti CK4010HST
Does anyone use, or know of, any type of protective covers for your lower link lift pins on your attachments during storage or between uses? I have a few used implements that have very rusty lift pins that will not go into the sockets on my tractor's lift arms. Before i cleaned them up, i figured i would see if there was anything out there to protect them from getting this bad in the future. I have done some searches, but i couldn't find anything out there. Thanks for any info.
   / Lift pin covers #3
If being that rusted and can't be wired brushed or worn out why not just replace them as the cost isn't that bad. My farm supply store has pins from 2 dollars up to 7 dollars depending on the size .
   / Lift pin covers #4
I smear grease on mine.
X2. Sounds like you aren't using that equipment enough. I have had equipment set for years un-used and lift pins never rusted enough so they would go in the lift arms. Clean off the rust and grease them up.
   / Lift pin covers #5
   / Lift pin covers #6
I often spray my pins with Fluid Film. It's a lanolin based aerosol that sticks pretty well. My tractor dealer carries it.
   / Lift pin covers #7
+1 on Fluid Film. In some northern climes, folks use it as automotive undercoating. Awesome stuff for the PTO splines too. Attracts/collects less dirt than most lubes.
   / Lift pin covers #9
I grease the heck out of the pins and jam them back into the equipment lifting points. All my equipment gets used enough so rust buildup is never a problem.
   / Lift pin covers #10
Brake cleaner spray works well removing rust than drill bit oil.
2015 TAKEUCHI TB290 EXCAVATOR (A51246)
2015 TAKEUCHI...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
(4) Sumitomo 11.00 R22 Tires (A51573)
(4) Sumitomo 11.00...
