Lift will only lift about 100 lbs
   / Lift will only lift about 100 lbs #1
froggyo
I have a Massey 135 (70's), and the lift will only lift about 100 lbs. What should I look for. Someone said there may be water in the filter.
   / Lift will only lift about 100 lbs #2
Yeah, water will do it. Whens the last time you change the fluid? If it's more than 3 years, warm the tractor up to 45 degrees for 8 hours (overnight is better) and change the fluids and filters.
jb
   / Lift will only lift about 100 lbs #3
Perhaps the fluid level is low ?
Haired / iced over suction screen ?
Does the hydraulic pump whine a lot or is it quiet ?
Where are you at ? I mean how cold is it outside ? I don't think water in the filter will cause what you are seeing unless it is frozen, then it will for sure.
Do you have a remote on the tractor, will it work an attachment or something ok. ? If it works ok, your problem might be in the lift mechanism itself.
   / Lift will only lift about 100 lbs #4
For some strange reason, I'm having trouble posting to this thread with a link I'm wanting to pass on. I'll PM you with more info. I'm very familiar with 100 series Masseys. Water isn't good for the hydraulic system without a doubt. It can cause problems with the pump or lift cylinder. If, as was mentioned, you have water in there and it's froze, you have BIGGER problems.
Check you Personal Messages.
   / Lift will only lift about 100 lbs #5
Did you get your problem resolved? Post back when you find out what it was.
FORD F750 XL SUPER DUTY TRUCK (A51406)
FORD F750 XL SUPER...
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
Kalamazoo 8-6-W Metal Cutting Band Saw (A51695)
Kalamazoo 8-6-W...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
One pallet of miscellaneous items (A53117)
One pallet of...
