3-Point Hitch Lift won;t raise
   / Lift won;t raise #1
derrick1115
Albertville,Alabama
MF 135
I have Massey ferguson 135 tractor that I was bush hogging with the other day and i backing up a hill raising and lower the bushing as i was backing up the hill then went to put it forward gear i lowered it and now it wont come up. I have had this tractor awhile so i thought i would drain the fluid and change the filter out and see if that would help. Anything else i should check or do while i have all the fluid drained out?
   / Lift won;t raise #2
Check to see, if one of the quick connects came apart. After thought, you were probably using the 3 point hitch, so that's different.
   / Lift won;t raise #3
Check the fluid level. Backing up the hill, might have sent the fluid to the front. Some tractors are partially partitioned off. Try running the front of the tractor up the hill and see, if the lift starts working ... you might have to cycle it multiple times.
1999 UTILITY 102" X 53' REFER TRAILER (A51243)
1999 UTILITY 102"...
6' DISC HARROW (A51243)
6' DISC HARROW...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
RING 2 STARTS HERE @ 9:30 AM (A51243)
RING 2 STARTS HERE...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
Wolverine Mini Skid Steer Grapple Bucket (A50514)
Wolverine Mini...
