Lifting welding tanks
   / Lifting welding tanks #1
Pilot
Veteran Member
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
I have a pair of oxy acetylene tanks. Recently bought a cart for them. The cart has about a 4" high lip across the front, a barrier to just rolling the tanks onto the cart.
I have a bad back, so I don't want to try to lift the tanks onto the cart.
So the question is, how do I get the tanks onto the cart?
I do have an engine hoist. If I put the end caps on the tanks, can I hook onto the caps and are the caps strong enough to lift by?
Any other ideas?
   / Lifting welding tanks #2
Can you move the tanks at all, just don't want to lift them? If so, maybe dig a small 4" depression to lower the front of the cart into?
   / Lifting welding tanks #3
Build yourself a small ramp to roll the cylinders up on. Doesn't have to be long. Maybe 16" or so.
   / Lifting welding tanks #4
My cart has a lip too. I just tilt the cylinder back while rolling it. Then lever the bottom up and onto the cart. Shove the bottom of the cylinder with my foot. No lifting involved. The bigger the cylinder diameter, the taller lip that can be climbed.
   / Lifting welding tanks #5
A couple of two X fours laid flat makes it a two inch lift-twice.
   / Lifting welding tanks #6
Lots of ways to skin a cat. How about cutting off the 4 inch strap, then putting a hinge on one end of it and a latch on the other, fasten the hinge end onto the remaining body of the cart, and the other half of the latch on the other side. Roll in the cylinders and shut and latch the gate!:thumbsup: No lifting and no dropping the cylinders 4 inches to the floor.
James K0UA
   / Lifting welding tanks #7
That is what I also do, of course the cart I have now, only has a 1" lip:thumbsup:
   / Lifting welding tanks #8
You could certainly lift the bottle by the cap if it was screwed down all the way AND you had some kind of tongs that would fit into the holes but not grab the valve handle BUT there are much easier ways of doing it, 1) just tilt the bottle back and roll it up onto the cart then stand it up is my way, but I don't have a large lip 2) build a small ramp to lay on the cart and then roll you bottle up the ramp. THIS is the way the LWS trucks load them into their TOMMY LIFT. I like the idea of a hinged ramp on the cart that you could fold up and lock in place on the cart so you can have it whenever needed AND it would help secure the bottles when folded up. An 8" long plate would allow a 45 degree ramp for a 4 " lift and that should be easy to roll a bottle up that slope. I may just do that for my bottle cart and do away with the strap I have to put on each time to hold in the bottom of the bottle.
   / Lifting welding tanks #9
Years ago, when I worked in a shop. We welded a strap across the cap and used a crane to move/lift the tanks. You could do the same using your engine lift
   / Lifting welding tanks #10
Any other ideas?
If I where in your position, I'd call for some help. No point in making your condition worse. No point in endangering your life and everyone in the area if something catastrophic happened. Just my :2cents: Take care. -robert
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
2009 GMC C5500 Landscape Dump Truck (A55788)
2009 GMC C5500...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
