Greetings,
I have a 2005 Terramite T5C with a Kohler Command 20 hp engine. Everything is great except when I turn my lights on which kills my engine. When this first happened a couple of weeks ago as I had turned on the head lights and was moving when it blew the fuse, on two different occasions. I changed the fuse both times and it hasn稚 blown one since.
Today I intended to fix this problem thinking it was only a short or grounding problem. It turns out not to be that simple. Even when the tractor is sitting still and I turn the lights on it will kill the engine but it doesn稚 blow a fuse. It seems I must wiggle all of the connections and wait a few minutes until something resets before I can start the engine again. The last time this happened I disconnected the wiring harness at the engine and then was able to get it to start.
Any suggestions or advice would be appreciated.
Thanks,
ron
Thanks,
ron
