lakngulf
Veteran Member
A few weeks ago I had a tree guy cut some huge pines that were leaning. Couple were near field lines so I had them just put the limbs and trees on the ground for me to move in dry weather. Seems they did not cut all the limbs close to the trunk, and when tree fell, some sizeable ones drove into the ground. So much so that I had to pull a couple out with chain attached to FEL. Since then I have had some oozing in that area, and the ground has become mushy. I dug in to see what I could do, and now have it clearing out. I know I am almost to the lines because I hit the rock bed that I put in around the pipe. What should I do now? Do you think that repair will be needed to the pipe? Just fill back up with better dirt? Add pipe in the ditch I have dug? HELP!! When finished with this issue, I do plan to add 6-8 inches of soil on the entire field line area.
