Line Leak Below Valve Drains Tank ????
   / Line Leak Below Valve Drains Tank ???? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
This is an off the wall question but I am just trying to figure out how this happens to get a better under standing. I have a small dozer and when I get a hydraulic leak in a line or hose down stream from the control valve it will drain the tank. Has happened 3 times over the years. Some times the tank drains to the return line level and other times the suction line. My tractor does not do this but the tank is lower. The dozer valves are more complicated with load checks and anti cavitation valves that I am not clear on but looking a the diagrams I can't see a leak path to the tank. So what is happening.
It is disconcerting when you crack a line and don't know it then when you come back a couple weeks later there is oil on the ground and the tank 2/3 empty.
gg
   / Line Leak Below Valve Drains Tank ???? #2
Don't have a dozier but do excavator and never had this to happen with it. Wondered about the vent cap but hard to believe the vent is it. Wonder if there is suppose to be a check valve in the return line and it is stuck or has failed or missing.
   / Line Leak Below Valve Drains Tank ???? #3
Is the reservoir higher than the valve stack? If yes it is possible that a line cracked could allow oil to be siphoned across the anti-cav checks and drain the reservoir. The anti-cav check have very low cracking pressure are intended to draw oil from the return line into the system to prevent cavitation.
Thank you. Yes, the oil level in a properly full tank is well above the valve stack. Also the tank breather is designed so that the tank builds up and holds pressure. Enough that you can hear it escape when you open the 4" cap. That wouldn't last long with oil leakage but it might help get a siphon action going ???
gg
2017 KOMATSU  D61 PXI-24 (A52472)
2017 KOMATSU D61...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2011 New Holland Boomer 90 MFWD Utility Tractor (A52748)
2011 New Holland...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
Toro Zero Turn (A50324)
Toro Zero Turn...
