LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
Item Details
Auction ID
51222
Make
Link-Belt
Type
Trucks & Vehicles
Auction House
EquipLinc Auctions, LLC
Idaho
BILL OF SALE ONLY
UNIT HAS BEEN SITTING FOR OVER 2 YEARS
UNIT DOES NOT RUN WILL NEED TO BE HAULED
YEAR UNKNOWN
SOLD AS-IS
*TRACTOR NOTES
TIRES WORN AND DRY ROTTED
KING PINS WORN
BRAKE DRUMS RUSTED
WINDSHIELD CRACKED
IGNITION SWITCH MISSING
BATTERIES ARE BAD
WIRES CUT UNDER DASH
ENGINE OIL LEAKS
AIR LINES CRACKED
REAR HYDRAULIC STABILZER OPERABLE
FRONT HYDRAULIC STABILZER INOPERABLE
*YARDER NOTES
MASTER SWITCH FOR YARDER INOP
EXCESSIVE HYDRAULIC AND OIL LEAK ON YARDER ENGINE AND HYDRILIC SYSTEM
HYDRAULIC LEAKS ON TOURET
REDUCTION PUMP LEAKING
YARDER ENGINE HAS A FUEL LEAK
YARDER IGNITION SWITCH WILL TURN ENGINE BUT SHUT OFF IS DISCONNECTED HAD TO DISCONNECT FUEL PUMP TO SHUT THE YARDER MOTOR OFF
*DYE BOOM NOTES
BOOM APPEARS STRUCTURALY SOUND NO VISIBLE CRACKS
CABLES ARE TATTERED AND CUT
RAISE CABLES ARE IN GOOD CONDITION PULLEYS ARE RUSTED NEED GREASE
CABLE WOULD OVERLAP
PTO LEAKS
CHAIN REDUCTION UNIT CHAIN STRETCHED AND RUSTED
CAB CONTROLS INOPERABLE WITH EXCEPTION OF TOURETTE VERY LITTLE MOVEMENT
ENGINE SHUT OFF INOPERABLE
THROTTLE INOPERABLE
PULLY CONTROLS INOPERABLE
UNITLOCATED IN ELK RIVER,IDAHO
INSPECTION DATE 7-16-25
This is a live bidding auction by EquipLinc Auctions, LLC
2759 US Hwy 431, Roanoke, AL 36274
Starting Bid: 1000.00 USD
Auction Day: August 05, 2025 at 04:00 PM
Click Here To Bid Now!
Happy Bidding!
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
Oil Well Pump Jack with Motor (A49461)
Oil Well Pump Jack...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
