Link lifting arm stuck in up position after filter(s) changed
   / Link lifting arm stuck in up position after filter(s) changed #1
TN8Man
Platinum Member
Tennessee
TYM T494C, EA Root Grapple. JD445
After changing my hydraulic and HST filter(s), then adding back fluid, my link lifting arms are stuck in the up position. Everything else in the hydraulic system seems to work fine.
Any ideas?
Found the problem. I adjusted the lifting arm (lower link) speed control lever and it came back to life.
   / Link lifting arm stuck in up position after filter(s) changed #3
Glad you got it working.
good that you posted the solution too - that helps the next guy searching the same issue.
300 Gallon LP Tank (A49339)
300 Gallon LP Tank...
2020 Ford Explorer SUV (A46684)
2020 Ford Explorer...
90in. Work Bench (A49339)
90in. Work Bench...
1575 (A46502)
1575 (A46502)
Yale KELI-20LG15S1 1 Ton Electric Chain Hoist (A49339)
Yale KELI-20LG15S1...
Ver-Mac PCMS-3812 (A45336)
Ver-Mac PCMS-3812...
