Flat Proofing liquiTube testimonial
   / liquiTube testimonial #1
heppeone
Had a pretty big gash on my Kubota L3750 rear tire. Had surgery on my shoulder & was unable to remove to take to shop, service truck plus cost of tire was too much, or patch/tube. Found liquiTube online, found it at a local Napa and put it in tire. Easy. Months later, still no leak. I'm sold. Going to order larger size and put in the remaining 3 plus the 4 on the MF. They sell all sorts of quantities, I got the 1 gal size, but they have 5 gal, 55 gal and much larger if needed. Dot otr approved.
   / liquiTube testimonial #2
Does anyone know what is the difference between LiquiTube and Slime?
   / liquiTube testimonial #3
LiquiTube seals anyleaks that you may have in the tire and it also is only made for slow moving vehicles. Slime I believe is a liquid ballast to put in the tire.
   / liquiTube testimonial #4
slime is not ballast
BXman98, Slime is not a ballast, its a sealant. Though the company may make a ballast compound I'm not aware of. As far as the LiquiTube, it says its DOT approved for OTR (Over The Road) use. I read user testimonials from trucking companies. Either way, great product. Still no leaks.
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A50323)
2012 Peterbilt 337...
