Bobbie couldn't lift it by itself. Actually, the picture with the bale in the air came when I pulled it off the bed of my pickup.
The wife bought her lastest horse right after I told my brother that I didn't need the last two 1000# bales that he made for me. Based on the horses feed rate I would have run out of hay June 19th - we close on our new house on the 16th - no time to go get any hay; even IF it was dry enough for any hay to be baled. So Saturday I visited my brother and parents and came back with one of his normal sized bales.
The wife had to sit on the tractor and lift with the loader while I lifted on the bale to get it off of the pallet that I had set it on. The bale barely cleared the pallet. Then I drove down into the pasture and anticipated the bale bottoming out - I was ready and hit it with speed, the differential lock engaged, and lifting with the loader. Eureka! I had the bale high enough to get it into the feeder - BUT... I only had three wheels contacting the ground! One rear wheel was clearly off the ground - yet the bale was still in the air.
I made it TO the feeder - It took me another 20 minutes to get it INTO the feeder. I had to cut the wrap and pull a layer of hay off the side. I also pushed the feeder back 40' in the process.
Once the bale was in I put a chain on the feeder to pull it back into place. I had to use the bale spear as a climbing pick to move the feeder back into place.
Guesstimate the bale at 1600#
Rated lifting capacity 20" in front of the pin 1220#
Tractor weight 3500#
Counterweight on the 3-pt 900#
The little tractor that COULD!
