LK2554 leaking oil
   / LK2554 leaking oil #1
rtaylor45
alexandria louisiana
LK2554
:confused:LK2554 leaking oil while engine running, out of dip stick and breathing tube, any suggestions?
   / LK2554 leaking oil #3
The only thing I am aware of to cause that much blowby is the rings are bad or a hole in a piston.
   / LK2554 leaking oil #4
Plugged crankcase ventilation? If not (e.g. rings or piston) it will be costly.
only time it blows off is when I raise rpms up to 2500. seems to be good below that, ran for 6 hours 100 to 1500 rpm and no blow out. is there a cleaner to see if I can clear pistons or rings.
   / LK2554 leaking oil #6
You could do a compression test also. Not sure where the breather is?
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
SHREDDER (A52472)
SHREDDER (A52472)
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
