philshel
Bronze Member
I am having an issue with my '99 LK3054 that I'm hoping someone here will be familiar with. There is a bit of a back story. The tractor developed a leak between the rear of the transmission and the rear-end casting. I split the tractor and repaired the leak with a form a gasket product, leak fixed. However after putting everything back together the hydraulics are making a noise and now I'm getting a hydraulic leak from the top of the steering column. The sound is sort of a squealing vibrating sound, it sounds similar to the the pressure valve releasing pressure. The sound seems to be coming from the rear on the right side of the seat. There is a rear remote kit on the tractor. Before I brake it in two again, does anyone have any idea as to the issue?
