There are two places you could do the quick disconnect connections first. One is at the top of the loader mount on the right side where you would disconnect to remove the loader and the other is under the right floor board at the actual valve. I don't know your loader year but mine is the older style where all the lines go into the arms and then into the front cross member. There is an inspection plate on mine and if you remove that, there is a distribution block that the lines connect to. I was present when the dealer installed the loader and he had to remove the plate to tighten up the lines because of a leak. As mentioned, with the lines disconnected and if the lift and bucket roll reasonably stay, the cylinder seals are good and it's the valve. If the arms and roll move, it's the piston seals in the cylinders which can be replaced. If it's the valve block, you'll probably need a new one but I believe you can get various parts if you know what is malfunctioning. As mentioned, it doesn't have fluid flow seals but steel rods called spools that move back and forth in a very close tolerance bore. I never had mine apart before but there may be flow check valves that could be leaking. A valve block schematic would show them. I had some problems with my bh valves on a KB2375 and flow check valves are in these. You'll just have to narrow down where the leak is, (cylinder piston seals, valve block) and then repair or replace what is leaking the fluid.
