Loader for Ford 8N
/ Loader for Ford 8N #1
NH Mike
Bronze Member
Atkinson, NH
ASV PT-60, Case 310B, Deere B, Ford 8N, Hustler Raptor SD.
Built a complete loader attachment for a Ford 8N and shortened the Deere loader arms.
Note the full subframe under the stock 8N.
/ Loader for Ford 8N #2
Nice work.:thumbsup:
/ Loader for Ford 8N #3
Nicest one I've ever seen on an N!!!
Looks like you did a lot of planning. Fantastic work my friend.
What's your gpm with that set up?
Thats the stock pump that came with the old loader. Not sure of the GPM but its fast and seems plenty powerful.
/ Loader for Ford 8N #6
Congratulations. That is one best front end loader set ups I've seen, if not the best.
Thanks, it was a ton of fun building it. The tractor is for sale if anyone's interested.
/ Loader for Ford 8N #8
Nice work... looks 'right'.
Is the front axle and/or tires up to handling the weight of the loader and whatever it can lift?
/ Loader for Ford 8N #10
looks great. too bad it's on an N.. ;)
/ Loader for Ford 8N #12
LMAO!
that would look great on a late 4cyl 4000 with one of the industrial axles. either light or heavy.. and the real power ssteering.. not that jinky cable setup.
Heck.. while I'm making a list, a reverser trans and an upgrade to a 192, with a medium sized 3pt hoe setting in the garage that was made to hook tot he existing subframe... hmm.. guess rops too. ;)
there.. list done... ;)
Ok, I get it... But lets keep things in in perspective. My 75 year old father can't move things the way he use to, so we built a loader for one of the tractors he owns as a project to do together as well as some utility. Between his Deere B, the 8N and my old case 310b he can get plenty of work done. And if we need more I have an ASV PT-60 to fill in the gap.
This loader is less weight on the front than the original, but we have contimplated attaching a HD axle right under the new subframe, not that much work involved.
/ Loader for Ford 8N #14
That's a really great looking design with a lot of excellent workmanship in it. I guess it's not a quick detach unit, huh?? :rolleyes: Just kidding there. I have to ask though, why would you go to all that work (even though you enjoyed doing it) just to turn around and sell it????
Just making room for more projects. And yes the loader is built to be removable but the subframe stays in place.
/ Loader for Ford 8N #16
IT does look great.
How does it steer? both loaded and empty?
/ Loader for Ford 8N #17
nice...really nice
It steers the same as the stock loader, you need to start moving when you turn the wheel. Would be easy to add hydraulic steering to the subframe.
/ Loader for Ford 8N #20
Wish I had the Dearborn loader you took off. Wish I never scrapped the one off my dads 8n ;-(
New/Unused Wolverine Quick Attach Ripper (A61166)
New/Unused...
17102 (A56859)
17102 (A56859)
New/Unused Landhonor 8ft X 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
2014 Case IH 315 Magnum (A62177)
2014 Case IH 315...
