Loader Hydraulic Problem after replacing hose
   / Loader Hydraulic Problem after replacing hose #1
Fluoronator
Massey 231s, NH 1725
I blew a hydraulic hose on the loader of my New Holland compact tractor. After replacing the hose I have two new problem with the loader hydraulics. First, pushing the joystick to the quick dump position causes the bucket to reverse directions and scoop instead of dump. Secondly, the bucket will only move half way when scooping and then it acts like it's reached it's positive stop.
I'm sure I didn't reverse any hoses because I only removed/replaced the damaged one. I was careful to bleed air from the hose and also topped off the fluid. What could be the problem?
   / Loader Hydraulic Problem after replacing hose #2
That is a symptom of air in the cyl's Purge the air by cycling the system many times
Check your QD's for good connection also.
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
2010 Autocar Xpeditor T/A Labrie CLSFRH 33 CuYd Side Loader Garbage Truck (A51692)
2010 Autocar...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
