Loader Leakdown
   / Loader Leakdown #1
Matt4200
Central Indiana
John Deere 4200
Anyone got a good idea of what normal leakdown should be for a 4200 with a 420 loader? Mine seams to go down faster than I thought it should for a 2000 machine with about 150 hrs. I got the acceptance spec from my dealer. It says that it shouldn't leak down at the cylinder rod more than 5.9 inches/hour. To me that would be a LOT. I measured mine and it went down about 1.5 inches/hour while sitting with an empty bucket. I was using it the other day for kind of a scafold with my homeade fork attachment with a pallet on it. It dropped about a foot at the forks in about 30 minutes. Can anyone give me some feed back on what their tractor is doing??? Thanks in advance!
   / Loader Leakdown #2
How about a stupid question. I read alot about loader leakdown, does this occur with the tractor running?
   / Loader Leakdown #3
Matt & Au...as anyone on this forum will tell you: there are no stoopid queshtons et setra. By way of clarification, Matt, you didn't have your 4200 running while waiting the prescribed hour to measure bleed-down on the 420?? Any weeping around the cyl bodies or quick connex? I've never checked bleed-down on my 2yr/old 4200/hst/420fel/200+ tt. I guess shoveling horse pucky doesn't beg the need-to-bleed out of my cyls. However, now I'll have to test in case a problem may be specific to the 4200/420 breed. If the bucket is raised empty formaintenance or scaffolding, I jam a 4x4 or some sort of hell-for-stout bracer under the bucket. I just picture some hydr line busting or a pesky rat knawing a hose (joke)...anyway being flattened by a bucket is not fun, I imagine. Please let me know about your fork 'n pallet device. My 42's been a jewel.
   / Loader Leakdown #4
Here\'s Deere\'s Measure
Solution Number: 53760
Doc ID: WX53760
Solution Summary: Tractor Valve Leakage Rates When Equipped with Loader
Publication Date: Apr 19 2002
Complaint or Symptom: The boom or bucket cylinders extend or retract at an excessive rate
Problem or Situation: The allowable valve leakage tolerance needs to be known to diagnose loader leakage problems. If there is a problem, the source of the leakage needs to be determined (valve or one cylinder or both cylinders).
Solution:
Use the specifications below in addition to DTAC solution # 50824 "Loader Bucket/Lift Cylinders Extend or Retract" for diagnosis on loaders listed below.
70/410
Lift Cylinder …….. 7.52"/hour maximum 3.76"/hour nominal
Bucket Cylinder … 12.34"/hour maximum 6.17"/hour nominal
420 & 70
Lift Cylinder …….. 5.94"/hour maximum 2.97"/hour nominal
Bucket Cylinder … 8.59"/hour maximum 4.30"/hour nominal
430
Lift Cylinder ……. 4.81"/hour maximum 2.41"/hour nominal
Bucket Cylinder … 4.81"/hour maximum 4.08"/hour nominal
460
Lift Cylinder ……. 3.84"/hour maximum 1.92"/hour nominal
Bucket Cylinder … 5.70"/hour maximum 2.85"/hour nominal
520 & 521
Lift Cylinder ………3.84"/hour maximum 1.92"/hour nominal
Bucket Cylinder …. 5.70"/hour maximum 2.85"/hour nominal
521 "B" Position
Lift Cylinder ……. 3.03"/hour maximum 1.52"/hour nominal
540 NSL
Bucket Cylinder…. 5.70"/hour maximum 2.85"/hour nominal
540 SL / 541 NSL & 541 SL
Bucket Cylinder … 4.09"/ hour maximum 2.04"/hour nominal
620 / 720 & 740 NSL
Lift Cylinder ……. 1.89"/hour maximum 0.76"/hour nominal
Bucket Cylinder … 3.17"/hour maximum 1.27"/hour nominal
640 NSL & SL
Lift Cylinder ……. 1.17"/hour maximum 0.47"/hour nominal
725
Lift Cylinder ………1.53"/hour maximum 0.61"/hour nominal
Bucket (-5999)…… 3.17"/hour maximum 1.27"/hour nominal
Bucket (6000-)…… 2.28"/hour maximum 0.91"/hour nominal
740 SL
Lift Cylinder …….. 1.17"/hour maximum 0.47"/hour nominal
Bucket Cylinder … 2.28"/hour maximum 0.91"/hour nominal
840 on 7000 Series Tractors
Lift Cylinder …….. 0.93"/hour maximum 0.37"/hour nominal
Bucket Cylinder … 1.72"/hour maximum 0.69"/hour nominal
70, 440, 460, 520, 540, 620, 640, 720, 725, 740, 840, 410, 420, 430, 541, 521
   / Loader Leakdown
Re: Here\'s Deere\'s Measure
LazyK, I didn't have the tractor running. Although, I'm not sure it would make a difference if it was running or not? I guess it would depend on what is leaking. I've not noticed any external leakage anywhere in the hydraulics. About the forks. I've read some posts about them and I think most of you would like to see mine, not trying to brag or anything. I've never gotten the frame painted yet, so it doesn't look pretty yet and I don't have a digital camera, but will try to get a hold of one soon to get a picture or two to post. The forks are adjustable side to side and I can quick attach it to the loader in place of the bucket or on the 3 pth. I use them about as much as the bucket I believe. They're just a pair of well used forklift forks I bought for $50, but they're plenty for the 4200.
Joecdeere, I have a DTAC from the dealer, but not the same one you posted. Mine has about the same spec on it though. Got a question for you though. Do you have any access to DTAC's on the 4200 Syncshift transmission problems? Mine has a problem shifting into gear sometimes.
Thanks guys!
   / Loader Leakdown
Well today I disconnected the lift cylinders at the quick connects and then lifted a little weight by curling the bucket. The lift cylinders didn't move at all. That tells me that the leak is in the valve. I'll contact the dealer tomorrow and see what he says about it.
   / Loader Leakdown #7
Matt, send me your serial number, and which shifter isn't working right
   / Loader Leakdown
LV4200C327959 is the serial.
My problem is with trying to go from one gear to another, like first to reverse. NOT the range lever. It seems like the clutch doesn't disengage totally. It's really bad when facing a downhill slope. Some tell me this is because all the oil runs to the front where the clutches are. It's always a little hard to get into gear while sitting on level ground to me. I moved some dirt over the hill behind the house and dumped it while sitting on the hill and almost couldn't get it into reverse to get backed up the hill. I found that if I sort of slam it from first to reverse it will go easier. My dealer says it's something I'll have to live with. He did have a used one there which I tried out to see if it had the problem and it did, but maybe not as bad as mine.
Any help would be greatly appreciated.
Thanks!
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
Landoll Hauloll (A52128)
Landoll Hauloll...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2006 Ford F450 XL Bucket Truck (A47384)
2006 Ford F450 XL...
