wvpolekat
Platinum Member
DISCLAIMER: I fully realize that this does not have any trip mechanism and could result in any number of broken/bent items on my tractor and personal injury to myself including cancer of the eyelashes. I accept this risk because I know how this will be used and under what conditions. To me, the owner of said tractor and attachments, this is an acceptable, calculated risk. Please do not turn my build thread into preaching about this. I am well aware of it.
Just wanted to share my latest project which is a loader mounted blade made from my rear blade. The blade will be also be able to be converted back to a rear blade. It's primary use will be snow removal. If I need to move dirt, I will mount it back on the rear of the tractor.
My design was inspired by zmansmac. You can see his blade here and here.
I did not take as many pictures as I would have liked, but I will describe things as best I can. It really was a pretty simple build.
Parts list:
Approximate cost not including tractor or blade: $100
Tools Used:
The first step I took was to cut the main beam of the blade approximately 10" from the blade pivot. I wanted to keep this as short as possible because this will determine how far in front of the loader arms the blade will be.
After cutting the blade off, I turned to the loader mount. I first cut the 3x5 to be the same length as the distance between the outside of the bucket mounting brackets. I used the angle grinder for this to get a clean cut without grinding after using the torch.
Next up was the mounting brackets. These were modeled after the mounts on the back of the factory bucket. They were then cut from the remaining 3x5 steel tube. Lacking a 3/4" drill bit, the pin holes were cut using the torch in the skilled hands of my ex father in law who was helping me. They are not 100% clean, but the plan is to add 3/4" ID bushings like the factory brackets eventually.
Here is one before making the holes
After mounting the brackets on the loader arms and making sure the pins aligned properly and we had full range of motion, the beam was clamped in place and tacked. Range of motion was once again verified without binding, it was removed for final welding.
Here it is on the loader arms:
We had found that a 2.5" to 2" receiver hitch adapter sleeve fit perfectly inside the beam on the blade. This would also allow me to use any 2" receiver hitch pieces on the loader beam. One of these will also be used to rejoin the blade to it's 3ph frame. Added bonus is that it turns the 3ph frame into a 2" receiver hitch when the blade is not attached. It could be easily used as a starting point for any number of things.
Because of the short length of the sleeves we had available, we had to surface weld it to the beam. Ultimately, this proved to be a bad choice. During testing, it quickly broke off. I am getting a longer piece of 2.5x.25 square tubing and it will be run through the beam for much greater strength. Maybe it was a bad weld, but it was obviously the weak link. Unfortunately, I did not get a picture of the blade mounted before the weld broke.
Here is the broken weld, to me it looks like it had almost no penetration. I have had lots of things welded by him and never had a problem. Either way, it is what it is.:
Still to do:
Fix the broken weld with something stronger.
Add power angle. I have most of the parts for this, but it was just not a priority at this time.
Thanks for reading. Comments and suggestions welcome. UNLESS THEY ARE ABOUT THE LACK OF TRIP MECHANISM.
Parts list:
- Kubota B7500 with LA302 FEL
- County Line\TSC 6' rear scrape blade
- 6' piece of 3x5x.25 steel tubing ($70)
- 2.5" to 2.0" receiver hitch adapter sleeve.
- 4x 3/4" hitch pins from TSC
- 1x 5/8" Hitch pin from TSC
Tools Used:
- Oxy/Propane Torch
- Hobart MIG Welder
- 4" angle grinder with various cutoff, grinding and flap wheels.
- Assorted hand tools. Hammer, Punch, etc.
Still to do:
