loader on Tu180-240
   / loader on Tu180-240 #1
lens12
Veteran Member
Dixon, Il
ford 9700, tw30, massey, jd2030 jd4010, yanmar F60d, ym330d, ym276d,ym226d,ym186d, ym2000, ym155
Has anyone mounted a loader on a TU180/200/185/205/220/240 ? If so what mounting brackets & loader did you use?
   / loader on Tu180-240 #2
Yes, we used Koyker but unfortunately long ago only the 140 was available and it was too big. When the 125 came out we changed to it instead. Now we use the Frey ML165 which fits perfect but it is still not a very good tractor for a loader as I am sure you know.
Buck
   / loader on Tu180-240 #3
Guys.. How do you tell if a tractor is a good tractor for a loader?
Thanks..
I don't like to put loader on tractors with aluminum or steel clutch housings without a sub frame. The TU180-240 clutch housing & transmission are not bolted together. They have a driveshaft & frame rails connecting them. I would recommend a sub frame on this style also.
   / loader on Tu180-240 #5
Thanks..
TU models have a setback front axle which is good for tight turning but bad for loader stability. TU frames are parameter thin wall extruded tube with a rubber mounted engine just like a car. To put a loader on you have to build a completely separate frame like Len said.
Buck
2021 New Holland Workmaster 25S Compact Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 New Holland...
John Deere 6210E 120HP 4WD Agricultural Tractor (A50322)
John Deere 6210E...
2012 Hino 262 Rollback Tow Truck (A50323)
2012 Hino 262...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
John Deere 652R (A50121)
John Deere 652R...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
