Scozz and I have exchanged a PM about this. I asked if it lifted the front of the tractor easily and he said it did and that it seems to have plenty of down force but little up force. My thoughts (after eliminating all the excellent suggestions given thus far) are possibly a valve problem in the loader or a piston cup on one or both of the cylinders. It is possible for a cylinder to loose the ability to hold pressure in one direction if only one piston cup seal is damaged since they are normally only designed to hold pressure in one direction. The valve could be eliminated by swapping the lines, the valve will work backward, but if the loader then will not easily lift the front of the tractor, but has plenty of lifting power, the valve is the problem. a careful check of all quick connect fittings is also worthwhile.
