Loader problems..'powered down' stops working
   / Loader problems..'powered down' stops working #1
Sniggle
Jefferson County, WV
2003 Kubota B7800 (new to me @ 435 hours
My loader has been having a repeating (but infrequent) problem....the loader joystick will occasionally fail to activate 'bucket down' function. I will be able to push the joystick forward to activate float, but will not be able to find 'powered down'. This has happened 3 times, and each time 'powered down' returns in a minute or 2.
Any ideas on what is causing this...how to fix?
   / Loader problems..'powered down' stops working #2
Yep..happened to me and I figured it out quick.
Bet you were using your 3PH at the time.
The 3PH lever for up and down doesn't automatically go back to center, it's easy to leave it in the full up or full down position. When you do.....you get the exact problem you describe.
Always make sure your 3PH lever is in the middle after you have raised or lowered it and your loader should be fine.
   / Loader problems..'powered down' stops working #3
Same thing here with the 3PH lever. I got my scare while plowing snow last winter. Use a rear blade in reverse and the FEL in forward. When the "problem" repeated itself several times I had a few choice words slip out before I discovered the cause was me.
2014 JOHN DEERE 310K BACKHOE (A51406)
2014 JOHN DEERE...
2014 Homemade 16' Gooseneck (A50121)
2014 Homemade 16'...
2012 Freightliner M2 106 Ambulance (A50323)
2012 Freightliner...
John Deere TS Gator (A50121)
John Deere TS...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
