Loader Problems
   / Loader Problems #1
Red Barn Tractors
Gentryville, MO
T4-75, 861 Powermaster, 8Nx3
Having difficulty with the loader on my 2012 T4-75. Raising the loader is extremely slow in comparison to tilting the bucket in or out. Fluid level is ok, and all hydraulic functions seem fine with the exception of raising the loader. The cable between the joystick and hydraulic valve seems to be good and all lines seem to be good as well. Thanks in advance for any ideas or suggestions?
   / Loader Problems #2
Has it always been that way, or is this something new??
SR
   / Loader Problems
just started. last summer extensive use of loader. no problem.
   / Loader Problems #4
Disconnect and reconnect your quick connections on the passenger side...
   / Loader Problems #6
What are you looking for? An air bubble? A poor connection? Or just something simple worth a try?
I'd also say to take a second look at the cable between joystick and loader valve. Is that cable stranded? If a couple of strands break the rest will start to stretch.
I'm guessing it's not cylinder seals. They usually start to squawk before they change speed much.
rScotty
JOHN DEERE 333G LOT NUMBER 241 (A53084)
JOHN DEERE 333G...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2024 Dig Master DM-F20 Electric Fork Lift, NEW! (A52384)
2024 Dig Master...
FORD 8770 TRACTOR (A51247)
FORD 8770 TRACTOR...
