Loader Valve with Remote Cable Controls FOUND!
   / Loader Valve with Remote Cable Controls FOUND! #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
I just wanted to post this link for al of you wanting to convert your loader mounted control to a fender mounted joystick. I priced the kit for my L4200 Kubota and it is $800 for the OEM part this is $300 I am a happy tractor guy!
Surplus Center Item Detail
   / Loader Valve with Remote Cable Controls FOUND! #2
Be carefull with the valve you posted. It is a closed center / load sensing valve. This valve may not be a good match for your Kubota hydraulic system. I believe Kubota's are open center systems.
Also, that is a 29gpm valve, which means it is going to be a sizable chunk of iron.
Make sure the valve is compatable with your tractor system. Using a closed center / load sensing valve in an open center power beyond circuit might not be a good thing for the hydralic pump.
   / Loader Valve with Remote Cable Controls FOUND! #3
My Kubota L4330 is an open center system, so your L4200 is also likely to be open center. If so a valve designed for a closed center system will not work. Actually, it may work for a while, but it will block the pump flow when the spools are centered, causing the fluid to pass through the system relief valve when the pressure builds up, which keeps a constant strain on the pump and heats the fluid very quickly.
Thanks for the info guys, i knew it was too good to be true, I hate to spend the money on the Kubota cable joystick, But i have to come up with something, i am going to be building a custom cab on it soon and I hate the loader mounted stick as it is, any suggestions on another company that sells an open center valve?
   / Loader Valve with Remote Cable Controls FOUND! #6
I assume Kioti DK series are the same, open center system.
3121 (A49339)
3121 (A49339)
LandPride BB1566 (A47307)
LandPride BB1566...
NEW Fork Extensions (A48289)
NEW Fork...
OMI 27ft. Pasture Harrow (A49339)
OMI 27ft. Pasture...
2003 Boat Master BC27GVH 23ft Tri-Axle Boat Trailer (A44571)
2003 Boat Master...
30in.x57in. Welding Table (A49339)
30in.x57in...
