Loaders and Lights
   / Loaders and Lights #1
SethO
It seems that once you have a loader, your front lights are useless. I wonder whether we should have a situation whereby additional lights are installed with your loader, the lights can either be on the ROPS or elsewhere, but definitely high enough to be useful.
Any comments?
Seth
   / Loaders and Lights #2
seth, 'useless' is such a strong word. you don't feel that lighting the back of the bucket is useful ??? /w3tcompact/icons/grin.gif.
there have been many threads about ligthing and the various and creative ways to mount and wire them. try a search under 'customization'. I have added ( 2 ) trap halogens facing forward and a flood facing the rear. all are mounted to the underside of the rops cross member.
   / Loaders and Lights #3
It's very common to add lights to the ROPS (with some aimed forward and some aimed backwards). I had a canopy on my last tractor and mounted the lights to the canopy frame (under the canopy). I don't know about the BX, but the B series Kubotas already have a fused circuit with a wire under the seat to tie into for optional work lights. You just need the lights, mounting brackets, wire, and switch.
   / Loaders and Lights #4
It's interesting that you bring up a connection "under the seat" as there seems to be one on my BX-22 that might meet that description. I haven't had time to check it out with a meter yet, but it definately would solve the, "How to I get power to the ROPS?" question. Although Mother Nature did the snow removal today in SE PA, the FEL does interfere with night-lighting should that be necessary.
   / Loaders and Lights #5
You could mount the lights on the loader frame, just near the bucket. Since you already have hydraulics, you could add a hydraulic Auto-gyrotational leveler to the brakets, so the lights remain level and pointing forward, no matter the position of the loader.
Of course, the auto-gyro levelor would probably cost twice as much as the tractor did/w3tcompact/icons/grin.gif
   / Loaders and Lights #6
Jim, if it's the same as the B series, it has a fuse in the fuse panel and is wired through the ignition switch (only hot when the key of turned on).
   / Loaders and Lights #7
Thanks, Bird. I'll check it out when we return from the Turkey-day festivities in the land of disorganization...err, my wife's sibling's dinner celebration. <G>
(Great name, BTW...this is a "bird-friendly" houshold - <A target="_blank" HREF=http://sawsndust.com/birdies.htm>http://sawsndust.com/birdies.htm</A>)
   / Loaders and Lights #8
My tractoris a 4010 and has a 20 amp alternator. How many lights can I add. I was thinking 2 facing forward on the ROPS and 1 facing rearward. I have no idea what the working load is. What do you do for a switch?
On another but related note, what are the pros and cons of using my loader to remove snow vs. a blade on the rear?
   / Loaders and Lights #9
found that out did u? /w3tcompact/icons/smile.gif I only use at night for plowing snow, and it is a pain not to have sufficient light.
   / Loaders and Lights #10
BIRD: i took a quick look for that wire for additional lights did not see it under the seat , course i was in a hurry and just glanced, 1998 b2400.
John Deere 455G Loader (A48837)
John Deere 455G...
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
2016 KUBOTA SVL95-2S SKID STEER (A51242)
2016 KUBOTA...
2013 VOLVO VNM DAY CAB (A51222)
2013 VOLVO VNM DAY...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2021 Chevrolet...
