log skidder for Ford 1920 and/or TC40DA
   / log skidder for Ford 1920 and/or TC40DA #1
Danica
Ulster County, NY
CNH TC40DA & Ford 1920
Yesterday, my stupid boyfriend convinced me to get in my tractor and pull on a series of chains attached pretty high up on a dead tree that was leaning towards the power lines. I wanted to wait and put in a snatch block or pulley to give myself a little angle so it wasn't going to come down right on me. Well guess what? He prevailed and i got hit by a pretty big branch on the shoulder and hand. I am bruised and pissed.
So now the question: is Farmi a better skidding winch than Wallenstein? I have read the former are bombproof while the Wallensteins are good but not in the same league. Aside from the comments about how stupid it was to pull a tree down on myself, what do you think about these skidders? And for the record, my family in the south are tough pulp-wooders so i know all about logging safety and don't know why i cut corners but i did and am luck to be alive.
Danica
   / log skidder for Ford 1920 and/or TC40DA #2
Danica
Time for a new boyfriend:laughing:
I'm not speaking from personal experience, but a winch is a pretty basic machine and I would not fret too much over the label but rather see good dealer support. But then there are a TON of old Farmi's out there still workin.
   / log skidder for Ford 1920 and/or TC40DA #3
I have the Farmi & love it. The Wallensteins are good as is Norse and other major brands. They are very basic which is why they are bombproof. If you can afford it get he winch. You will find other uses for it besides pulling trees.
   / log skidder for Ford 1920 and/or TC40DA #4
I have the Wallenstein. No complaints.
Get one with a protective cage.
   / log skidder for Ford 1920 and/or TC40DA #5
Fransgard, Farmi, Wallenstein, etc.. I think it's hard to buy a bad one.
I went with Tajfun and am very happy.
   / log skidder for Ford 1920 and/or TC40DA #6
I have a Wallenstein FX65 on my little/light 3032e. I use my winch to pull over trees that are leaning the wrong way a fair amount - one guy at the tree and one on the tractor. Being that the blade on the winch helps anchor the tractor so I can pull more than my tractor could pull if it were to only use the wheels. The ~150 ft of cable really helps out to get me out of harms way (have a snatch block just in case though). My absolute favorite feature though is that if I'm pulling a tree that happens to not cooperate, and will want to pull the tractor backwards, I can just let go of the rope and let it free wheel. I picture bad things happening with chains.
Like others have said, I don't think you can go wrong with any of the brands, and I just bought the Wallenstein because that was the easiest for me to get at the time.
   / log skidder for Ford 1920 and/or TC40DA #7
I recently got a new FX85, and the only complaint other than it lacking storage is that the clutch wasn't set tight enough from the factory. I can't even put a load on my idling tractor (the 5065e) while the clutch sits there smelling hot and the logs aren't moving.
I'm sure this will be easily rectified when I go back up with my bigger allen wrenches, but it was annoying yesterday in the field.
That’s interesting cuz I’ve never adjusted the clutch and it is *possible* that it is too loose which gave me much less pulling capacity. Will check manual on proper adjustment procedure.
   / log skidder for Ford 1920 and/or TC40DA #9
So you use your tractor for wood skidding on a regular basis?
If not and for the occasional use, I personally think a capstan winch may be more handy.
   / log skidder for Ford 1920 and/or TC40DA #10
I helped the neighbor drop and cut up a VERY large black walnut several years ago. He also had two very impatient friends helping and neither of them ever watched what other people were doing. I quietly removed myself and my equipment from the danger zone until it was safe. It was a wonder nobody was killed that day.
Front Weight Bracket Magnum (A46502)
Front Weight...
Ferguson S-B041 3pt. Harrow (A49339)
Ferguson S-B041...
2001 FORD F-250 SUPER DUTY (A47001)
2001 FORD F-250...
Oregon ML350 Hydraulic Lawn Mower Lift (A46502)
Oregon ML350...
Pigeon Hole Cabinets and Parts Drawers (A45338)
Pigeon Hole...
2012 STAGECOACH TRAILER MONORAIL (A47001)
2012 STAGECOACH...
