log splitter
/ log splitter #1
swampy2
Montgomery,Indiana
John Deere X595
I would like to know if there is a log splitter available for my X595. I have a 3 point hitch but i do not have a pto yet. I have a outdoor wood burner to heat my house, shop, and water. I have been going through alot of wood and need a splitter bad. Should I just buy a reguler pull behind gas log splitter or is there one available for my lawn tractor that i could hook up to hydraulics or pto. need help? Thanks
/ log splitter #4
This is what you have now.
Hydraulics:
Pressure: 1000 psi [69.0 bar]
Valves: 2
Total flow: 6.2 gpm [23.5 lpm]
Not real suitable for a tractor log splitter.
Recommend you get and engine driven log splitter.
/ log splitter
thanks JJ. is there one you recommend. I would like to have something with a Honda engine. willing to spend 2000.00 but preferably less
/ log splitter #7
JJ has it right. Your little mower doesn't have the pressure/gpm necessary. I have no experience with the towed models. There are many out there. Unless you are doing production work for resale probably any will do you well. Big box stores probably have the cheapest prices but you get no service. From what I have seen bigger is not necessarily better. I have a small 5 ton electric model (under $300) that splits stuff that surprises me. If I was in the market I would probably look at those in the 15 +/- ton range. My 30 ton 3 PT seems to be an big overkill.
Ron
/ log splitter #9
Take a look at the splitters at TSC.
/ log splitter #10
I'd also advise wallenstein or split-fire. Very high quality. Iron&oak and Brave are good quality as well but harder to find dealers for in my area.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TANK MANIFOLD (A58216)
1997 JCB  436B WHEEL LOADER (A63569)
1997 JCB 436B...
2017 Nissan Altima 4 door (A63118)
2017 Nissan Altima...
Deere TR48B Worksite Pro Trencher (A64047)
Deere TR48B...
