Log Splitters ....
   / Log Splitters .... #1
DAP
Veteran Member
From Orange County NY to Lincoln County ME
JD LX288 and a B7800
Thinking about getting a tractor mounted splitter.....Who are the vendors? What are the pro's and con's ... prices
Whose got one and how's it holdin up?
   / Log Splitters .... #2
Doug--
Lots of past traffic on this topic. I got one at Tractor Supply last Fall and used it on about a cord so far. Some say the 3-point splitters have a slow cycle time, but it's fine for my needs. Easy to store, and the current TSC model (a Husky? --I'm not sure) has its own stand which makes it easy to put on/take off the tractor, is easily flipped from horizontal to vertical, and works just fine. Money well spent.
   / Log Splitters .... #3
I have looked at these for a few months but without having a rear hydrolic port I am leaning toward a gas powered one. I have seen some for about 1000 bucks and adding the port to my tractor is going to be about 1100 without getting the splitter. Maybe I can find a diffrent way useing my FEL hydrolics.
Steve
Slow cycle time? Like ... how slow? It's gotta be faster than MY cycle time!
I'm lookin at <A target="_blank" HREF=http://www.timberwolfcorp.com/splitters/tw3hd/tw3hd.htm>this</A> unit also.
Anyone know this outfit?
   / Log Splitters .... #5
Doug, I have a Bush Hog splitter but Bush Hog no longer makes splitters so I don’t have any info on current brands on the market. Mine is a horizontal splitter and after using it for a couple of years I wish I had a vertical model. Gets kind of hard on the back loading mine. It will split anything I put in it and it is nice not having to deal with another engine.
MarkV
   / Log Splitters .... #6
Doug--as to cycle time, I don't find it slow at all. A friend who was working with me said he thought it was no slower than a midsized splitter with an engine, but I haven't used one of those for awhile so I don't know. Basically, if I put the lever back, go a couple steps and pick up a log, the wedge is about where I need it to be to get the log in when I get back.
The Timberwolf looks like a great machine; just a huge difference in price between it and the one TSC sells. Also, FWIW, the TSC one is side-to-side rather than in line with the tractor, and so doesn't stick as far out back.
I've seen posts with folks talking about a lot of bucks for rear remotes, but having them put on my TC33d cost about $280, if I remember right.
   / Log Splitters .... #8
Doug--
My recollection is the Timberwolf is about $1800 and the TSC/Husky is about $400.
   / Log Splitters .... #9
Now that I have this winter's firewood pile stashed in the garage, I'm thinking about next winter. Now I never mind spliting wood. Since I was about 12, I split wood for my grandparents, parents, or myself. My grandparents heated with wood back then, and I did it to help.
We don't heat the house with wood, but the fireplace is a high efficiency type that contributes to lowering the heat bill. It can hold several good size logs at once. I tell everyone that the fireplace is the wifes foundry. By spring, every grate we use is just gone. The webbing or bars are just gone. Not warped or sagging, just gone. So anyway...
We burn alot of wood. And I'm not a 14 year old kid who wants to split wood for hours on Sunday to supplement wrestling training.
I want a wood splitter, but I dont want to spend $2,000 either. Some of the ones at the discount stores would do the job, but I can't see spending that much money for something that, to me, does not appear to be built for log term use. Some of the more commercial type units look nice, but WOW are they expen$$ive! And I don't want one that tips vertical. To high center of gravety at highway speeds.
I have rear hydraulics on the tractor but dont want to be limited to using it with just the tractor. Want to be able to pull it with the garden tractor or ATV. Last spring I helped a friend take down a tree in his backyard in town. A big oak. Could not get the tractor in the backyard, that incident is what made me think. It would have been real nice to have a splitter, but if it was on the tractor - I would have been S.O.L.
Also, as other threads here have explained, if the splitter is on the tractor, you are limited what you can do with the tractor while splitting.
So now I'm thinking build one. My list of requirements are:
--It's own power. Independent of the tractor. I've got a 5 hp horizontal shaft or a 16 hp vertical that I can use.
--At least 25 tons splitting force. I get alot of elm, ash, fenceline oak. Don't want any problems with stringy blocks or crotches. Bud works for an excavating company and they have many rams. Need to see what he turns up with before I decide on a pump or motor.
--Big wheels. I don't like seeing small wheels rolling down the highway at 70 mph. Need a trip to the scrap yard for this stuff.
--Cycle time of 15 - 16 seconds. Again, ram selection will be a factor here.
--Horizontal only. Don't like the ones that flip down. A hydro cradle for the big logs would be nice, no a neccesity.
--A table for the split logs. After the ram pushes the log through the wedge, they would slide onto a table ready to stack. This would be hinged and would fold up out of the way during travel or when not needed.
I'm starting to assemble my list of materials. I'm guessing I can put one together that will almost outperform the woodprocessor ones at the price of an el cheapo from the discount stores.
The scrounging begins now. I want this ready to use before February.
   / Log Splitters .... #10
Bought one at Sandvigs, now Runnings, a couple of years ago for $899, well built, has already split 30+ cords of wood, best one I have seen or used.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
UNUSED Four-Layer Black Metal Storage Shelf (A50860)
UNUSED Four-Layer...
2017 Rogator RG1300B Dry Fertilizer Applicator (A51039)
2017 Rogator...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2008 Honda Pilot SUV (A50860)
2008 Honda Pilot...
